vserver fcp initiator show
Display FCP initiators currently connected
This command displays information about FCP initiators that are currently logged in.
If you do not specify a Vserver, the command displays all initiators logged into all FCP Vservers within a cluster. If you specify a Vserver but not a logical interface, the command displays information about all initiators connected to all logical interfaces within the specified Vserver.
If an initiator belongs to an initiator group or has a World Wide Port Name (WWPN) alias, the command displays this information.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Use this parameter to display the FCP initiators logged into the Vserver that you specify.
[-lif <lif-name>]- Logical Interface-
Use this parameter to display the FCP initiators that match the logical interfaces that you specify.
[-wwpn <FC WWN>]- WWPN-
Use this parameter to display the FCP initiators that matches the World Wide Port Name (WWPN) that you specify.
[-wwnn <FC WWN>]- WWNN-
Use this parameter to display the FCP initiator that matches the World Wide Node Name (WWNN) that you specify.
[-port-address <Hex Integer>]- Port Addres-
Use this parameter to display FCP initiators that match the port address that you specify.
[-alias <text>,…]- Initiator WWPN Alias-
Use this parameter to display the FCP initiator that matches the alias name that you specify.
[-igroup <text>,…]- Igroup Name-
Use this parameter to display the FCP initiator that matches the initiator group that you specify.
[-data-protocol {fcp|fc-nvme}]- Data Protocol-
Use this parameter to display the FCP initiator that matches the data protocol that you specify.
cluster1::> vserver fcp initiator show
Logical Initiator Initiator
Vserver Interface WWNN WWPN Igroup
vs1 vs1.fcp 2f:a2:00:a0:98:0b:56:13
2f:a2:00:a0:98:0b:56:15
igroup1
Displays information regarding all logged in FCP initiators.
