vserver fcp initiator show
Display FCP initiators currently connected
This command displays information about FCP initiators that are currently logged in.
If you do not specify a Vserver, the command displays all initiators logged into all FCP Vservers within a cluster. If you specify a Vserver but not a logical interface, the command displays information about all initiators connected to all logical interfaces within the specified Vserver.
If an initiator belongs to an initiator group or has a World Wide Port Name (WWPN) alias, the command displays this information.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver Name
Use this parameter to display the FCP initiators logged into the Vserver that you specify.
- [-lif <lif-name>]- Logical Interface
Use this parameter to display the FCP initiators that match the logical interfaces that you specify.
- [-wwpn <FC WWN>]- WWPN
Use this parameter to display the FCP initiators that matches the World Wide Port Name (WWPN) that you specify.
- [-wwnn <FC WWN>]- WWNN
Use this parameter to display the FCP initiator that matches the World Wide Node Name (WWNN) that you specify.
- [-port-address <Hex Integer>]- Port Addres
Use this parameter to display FCP initiators that match the port address that you specify.
- [-alias <text>,…]- Initiator WWPN Alias
Use this parameter to display the FCP initiator that matches the alias name that you specify.
- [-igroup <text>,…]- Igroup Name
Use this parameter to display the FCP initiator that matches the initiator group that you specify.
- [-data-protocol {fcp|fc-nvme}]- Data Protocol
Use this parameter to display the FCP initiator that matches the data protocol that you specify.
cluster1::> vserver fcp initiator show
     Logical    Initiator      Initiator
 Vserver   Interface  WWNN           WWPN          Igroup
 vs1       vs1.fcp    2f:a2:00:a0:98:0b:56:13
                                     2f:a2:00:a0:98:0b:56:15
                                                   igroup1
Displays information regarding all logged in FCP initiators.
 PDFs
PDFs
