vserver fcp initiator show
Display FCP initiators currently connected
This command displays information about FCP initiators that are currently logged in.
If you do not specify a Vserver, the command displays all initiators logged into all FCP Vservers within a cluster. If you specify a Vserver but not a logical interface, the command displays information about all initiators connected to all logical interfaces within the specified Vserver.
If an initiator belongs to an initiator group or has a World Wide Port Name (WWPN) alias, the command displays this information.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display the FCP initiators logged into the Vserver that you specify.
[-lif <lif-name>]
- Logical Interface-
Use this parameter to display the FCP initiators that match the logical interfaces that you specify.
[-wwpn <FC WWN>]
- WWPN-
Use this parameter to display the FCP initiators that matches the World Wide Port Name (WWPN) that you specify.
[-wwnn <FC WWN>]
- WWNN-
Use this parameter to display the FCP initiator that matches the World Wide Node Name (WWNN) that you specify.
[-port-address <Hex Integer>]
- Port Addres-
Use this parameter to display FCP initiators that match the port address that you specify.
[-alias <text>,…]
- Initiator WWPN Alias-
Use this parameter to display the FCP initiator that matches the alias name that you specify.
[-igroup <text>,…]
- Igroup Name-
Use this parameter to display the FCP initiator that matches the initiator group that you specify.
[-data-protocol {fcp|fc-nvme}]
- Data Protocol-
Use this parameter to display the FCP initiator that matches the data protocol that you specify.
cluster1::> vserver fcp initiator show Logical Initiator Initiator Vserver Interface WWNN WWPN Igroup --------- ---------- -------------- ------------- ------------------------- vs1 vs1.fcp 2f:a2:00:a0:98:0b:56:13 2f:a2:00:a0:98:0b:56:15 igroup1
Displays information regarding all logged in FCP initiators.
