Command reference
vserver fcp initiator show
Display FCP initiators currently connected
This command displays information about FCP initiators that are currently logged in.
If you do not specify a Vserver, the command displays all initiators logged into all FCP Vservers within a cluster. If you specify a Vserver but not a logical interface, the command displays information about all initiators connected to all logical interfaces within the specified Vserver.
If an initiator belongs to an initiator group or has a World Wide Port Name (WWPN) alias, the command displays this information.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <Vserver Name>] - Vserver Name
Use this parameter to display the FCP initiators logged into the Vserver that you specify.
[-lif <lif-name>] - Logical Interface
Use this parameter to display the FCP initiators that match the logical interfaces that you specify.
[-wwpn <FC WWN>] - WWPN
Use this parameter to display the FCP initiators that matches the World Wide Port Name (WWPN) that you specify.
[-wwnn <FC WWN>] - WWNN
Use this parameter to display the FCP initiator that matches the World Wide Node Name (WWNN) that you specify.
[-port-address <Hex Integer>] - Port Addres
Use this parameter to display FCP initiators that match the port address that you specify.
[-alias <text>,…​] - Initiator WWPN Alias
Use this parameter to display the FCP initiator that matches the alias name that you specify.
[-igroup <text>,…​] - Igroup Name
Use this parameter to display the FCP initiator that matches the initiator group that you specify.
[-data-protocol {fcp|fc-nvme}] - Data Protocol
Use this parameter to display the FCP initiator that matches the data protocol that you specify.
cluster1::> vserver fcp initiator show
     Logical    Initiator      Initiator
 Vserver   Interface  WWNN           WWPN          Igroup
 vs1       vs1.fcp    2f:a2:00:a0:98:0b:56:13
                                     2f:a2:00:a0:98:0b:56:15
                                                   igroup1
Displays information regarding all logged in FCP initiators.
