job schedule show-jobs
Display the list of jobs by schedule
The job schedule show-jobs command displays information about jobs that are associated with schedules.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-name <text>]- Schedule Name
Use this parameter to display information only about the jobs that are associated with the schedule you specify.
- [-affinity {Cluster|Node}]- Cluster / Node
Use this parameter to display information only about the jobs that match the affinity value you specify.
- [-owner <text>]- Owner
Use this parameter to display information only about the jobs that are owned by the nodes you specify.
- [-jobid <integer>]- ID
Use this parameter to display information only about the jobs that match the ID or range of IDs that you specify.
- [-jobname <text>]- Job Name
Use this parameter to display information only about the jobs that match the name you specify.
- [-scheduleuuid <UUID>]- Schedule Uuid
displays the Uuid of the specific job schedule.
The following example shows information about schedules that are associated with jobs:
cluster1::> job schedule show-jobs Name Type Owner Job ID Job Name Schedule Uuid ------------ --------- --------------------- ---------- -------------- ------------------ hourly Cluster - 98644 mirror-hourly 8bafba5a-ff9a-11eb-8531-005056a75903 weeklylog Node node0 1501 log-rotation 449c070c-ff9a-11eb-8531-005056a75903 weeklylog Node node1 1498 log-rotation 8bb0adca-ff9a-11eb-8531-005056a75903 weeklylog Node node2 1499 log-rotation b15fce61-ff9a-11eb-8531-005056a75903 weeklylog Node node3 1500 log-rotation 8bb14bd2-ff9a-11eb-8531-005056a75903 5 entries were displayed.
 PDFs
PDFs
