job schedule show-jobs
Display the list of jobs by schedule
The job schedule show-jobs
command displays information about jobs that are associated with schedules.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-name <text>]
- Schedule Name-
Use this parameter to display information only about the jobs that are associated with the schedule you specify.
[-affinity {Cluster|Node}]
- Cluster / Node-
Use this parameter to display information only about the jobs that match the affinity value you specify.
[-owner <text>]
- Owner-
Use this parameter to display information only about the jobs that are owned by the nodes you specify.
[-jobid <integer>]
- ID-
Use this parameter to display information only about the jobs that match the ID or range of IDs that you specify.
[-jobname <text>]
- Job Name-
Use this parameter to display information only about the jobs that match the name you specify.
[-scheduleuuid <UUID>]
- Schedule Uuid-
displays the Uuid of the specific job schedule.
The following example shows information about schedules that are associated with jobs:
cluster1::> job schedule show-jobs Name Type Owner Job ID Job Name Schedule Uuid ------------ --------- --------------------- ---------- -------------- ------------------ hourly Cluster - 98644 mirror-hourly 8bafba5a-ff9a-11eb-8531-005056a75903 weeklylog Node node0 1501 log-rotation 449c070c-ff9a-11eb-8531-005056a75903 weeklylog Node node1 1498 log-rotation 8bb0adca-ff9a-11eb-8531-005056a75903 weeklylog Node node2 1499 log-rotation b15fce61-ff9a-11eb-8531-005056a75903 weeklylog Node node3 1500 log-rotation 8bb14bd2-ff9a-11eb-8531-005056a75903 5 entries were displayed.
