job schedule show-jobs
Display the list of jobs by schedule
The job schedule show-jobs command displays information about jobs that are associated with schedules.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-name <text>] - Schedule Name
Use this parameter to display information only about the jobs that are associated with the schedule you specify.
[-affinity {Cluster|Node}] - Cluster / Node
Use this parameter to display information only about the jobs that match the affinity value you specify.
[-owner <text>] - Owner
Use this parameter to display information only about the jobs that are owned by the nodes you specify.
[-jobid <integer>] - ID
Use this parameter to display information only about the jobs that match the ID or range of IDs that you specify.
[-jobname <text>] - Job Name
Use this parameter to display information only about the jobs that match the name you specify.
The following example shows information about schedules that are associated with jobs:
cluster1::> job schedule show-jobs
Name          Type      Owner                  Job ID     Job Name
hourly        Cluster   -                      98644      mirror-hourly
weeklylog     Node      node0                  1501       log-rotation
weeklylog     Node      node1                  1498       log-rotation
weeklylog     Node      node2                  1499       log-rotation
weeklylog     Node      node3                  1500       log-rotation
5 entries were displayed.
