vserver cifs add-netbios-aliases
Add NetBIOS aliases for the CIFS server name
The `vserver cifs add-netbios-aliases` command creates or adds a list of NetBIOS aliases for the CIFS server name.
-vserver <vserver name> - Vserver
This parameter specifies the name of the Vserver for which NetBIOS alias are to be created or added.
-netbios-aliases <NetBIOS>,…​ - List of NetBIOS Aliases
This parameter specifies one or more NetBIOS aliases to be added to an existing list of NetBIOS aliases. A new list of NetBIOS aliases is created if the list is currently empty.
The following example creates a new list of NetBIOS aliases for Vserver vs_a.
cluster1::> cifs show -display-netbios-aliases
Vserver: vs_a
Server Name: CIFS_SERVER
  NetBIOS Aliases: -
cluster1::> cifs add-netbios-aliases -netbios-aliases alias_1,alias_2,alias_3
Vserver: vs_a
  NetBIOS Aliases: ALIAS_1, ALIAS_2, ALIAS_3
The following example adds several NetBIOS aliases for the CIFS server CIFS_SERVER on Vserver vs_a.
cluster1::> cifs add-netbios-aliases -netbios-aliases alias_4,alias_5,alias_6
Vserver: vs_a
  NetBIOS Aliases: ALIAS_1, ALIAS_2, ALIAS_3, ALIAS_4,
                   ALIAS_5, ALIAS_6
cluster1::> vserver cifs add-netbios-aliases -vserver v1 -netbios-aliases alias_7
Vserver: vs_a
                   ALIAS_5, ALIAS_6, ALIAS_7
