security session limit location create
Create per-location session limit
This command allows creation of a per-location management session limit that does not yet exist.
-interface {cli|ontapi|rest} - Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-location <text> - Location (privilege: advanced)
The specified location to which this limit applies. The limit with the location name -default- (in the Default IPspace) is the limit used for any location (in any IPspace) without a specific configured limit.
[-ipspace <IPspace>] - IPspace of Location (privilege: advanced)
This identifies the IPspace of the client location. If not specified, changes are made in the Default IPspace.
-max-active-limit <integer> - Max-Active Limit (privilege: advanced)
The maximum number of concurrent sessions allowed for this interface and location.
The following example illustrates creating a CLI limit for specific location.
cluster1::*> security session limit location create -interface cli -location 10.98.16.164 -max-active-limit 1
