security session limit location create
Create per-location session limit
This command allows creation of a per-location management session limit that does not yet exist.
- -interface {cli|ontapi|rest}- Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
- -location <text>- Location (privilege: advanced)
The specified location to which this limit applies. The limit with the location name -default-(in theDefaultIPspace) is the limit used for any location (in any IPspace) without a specific configured limit.
- [-ipspace <IPspace>]- IPspace of Location (privilege: advanced)
This identifies the IPspace of the client location. If not specified, changes are made in the DefaultIPspace.
- -max-active-limit <integer>- Max-Active Limit (privilege: advanced)
The maximum number of concurrent sessions allowed for this interface and location.
The following example illustrates creating a CLI limit for specific location.
cluster1::*> security session limit location create -interface cli -location 10.98.16.164 -max-active-limit 1
 PDFs
PDFs
