security login create
Add a login method
The security login create command creates a login method for the management utility. A login method consists of a user name, an application (access method), and an authentication method. A user name can be associated with multiple applications. It can optionally include an access-control role name. If an Active Directory, LDAP, or NIS group name is used, then the login method gives access to users belonging to the specified group. If the user is a member of multiple groups provisioned in the security login table, then the user will get access to a combined list of the commands authorized for the individual groups.
-vserver <vserver name>- Vserver-
This specifies the Vserver name of the login method.
-user-or-group-name <text>- User Name or Group Name-
This specifies the user name or Active Directory, LDAP, or NIS group name of the login method. The Active Directory, LDAP, or NIS group name can be specified only with the
domainornsswitchauthentication method andontapiandsshapplication. If the user is a member of multiple groups provisioned in the security login table, then the user will get access to a combined list of the commands authorized for the individual groups. -application <text>- Application-
This specifies the application of the login method. Possible values include amqp, console, http, ontapi, rsh, snmp, service-processor, ssh, and telnet.
Setting this parameter to
service-processorgrants the user access to the Service Processor (SP). Because the SP supports only password authentication, when you set this parameter toservice-processor, you must also set the -authentication-method parameter topassword. Vserver user accounts cannot access the SP. Therefore, you cannot use the -vserver parameter when you set this parameter toservice-processor. -authentication-method <text>- Authentication Method-
This specifies the authentication method for login. Possible values include the following:
cert - SSL certificate authentication
community - SNMP community strings
domain - Active Directory authentication
nsswitch - LDAP or NIS authentication
password - Password
publickey - Public-key authentication
usm - SNMP user security model
saml - SAML authentication
[-remote-switch-ipaddress <IP Address>]- Remote Switch IP Address-
This specifies the IP address of the remote switch. The remote switch could be a cluster switch monitored by cluster switch health monitor (CSHM) or a Fibre Channel (FC) switch monitored by MetroCluster health monitor (MCC-HM). This parameter is applicable only when the application is
snmpand authentication method isusm(SNMP user security model). -role <text>- Role Name-
This specifies an access-control role name for the login method.
[-comment <text>]- Comment Text-
This specifies comment text for the user account, for example, "Guest account". The maximum length is 128 characters.
[-is-ns-switch-group {yes|no}]- Whether Ns-switch Group-
This specifies whether
user-or-group-nameis an LDAP or NIS group. Possible values are yes or no. Default value is no. [-second-authentication-method {none|publickey|password|nsswitch}]- Second Authentication Method2-
This specifies the authentication method for the login. It will be used as the second factor for authentication. Possible values include the following:
password - Password
nsswitch - NIS or LDAP authentication
none - default value
[-is-ldap-fastbind {yes|no}]- LDAP Fastbind Authentication-
This flag specifies whether the authentication is LDAP fastbind or Not. Default:false
The following example illustrates how to create a login that has the user name monitor , the application ssh , the authentication method password , and the access-control role guest for Vserver vs :
cluster1::> security login create -vserver vs -user-or-group-name monitor -application ssh -authentication-method password -role guest
The following example illustrates how to create a login that has the user name monitor , the application ontapi , the authentication method password , and the access-control role vsadmin for Vserver vs :
cluster1::> security login create -vserver vs -user-or-group-name monitor -application ontapi -authentication-method password -role vsadmin
The following example illustrates how to create a login that has the user name monitor , the application ssh , the authentication method publickey , and the access-control role guest for Vserver vs :
cluster1::> security login create -vserver vs -user-or-group-name monitor -application ssh -authentication-method publickey -role guest
The following example illustrates how to create a login that has the user name monitor , the application http , the authentication method cert , and the access-control role admin for Vserver vs :
cluster1::> security login create -vserver vs -user-or-group-name monitor -application http -authentication-method cert -role admin
The following example illustrates how to create a login that has the Active Directory group name adgroup in DOMAIN1 , the application ssh , the authentication method domain , and the access-control role vsadmin for Vserver vs :
cluster1::> security login create -vserver vs -user-or-group-name DOMAIN1\adgroup -application ssh -authentication-method domain -role vsadmin
The following example illustrates how to create a login that has a group name nssgroup in the LDAP or NIS server, the application ontapi , the authentication method nsswitch , and the access-control role vsadmin for Vserver vs . Here is-ns-switch-group must be set to yes :
cluster1::> security login create -vserver vs -user-or-group-name nssgroup -application ontapi -authentication-method nsswitch -role vsadmin -is-ns-switch-group yes
The following example illustrates how to create a login that has the user name monitor , the application ssh , the authentication method password , the second authentication method publickey and the access-control role vsadmin for Vserver vs :
cluster1::> security login create -vserver vs -user-or-group-name monitor -application ssh -authentication-method password -second-authentication-method publickey -role vsadmin
The following example illustrates how to create a login that has the user name monitor , the application ssh , the authentication method password , the second authentication method none and the access-control role vsadmin for Vserver vs :
cluster1::> security login create -vserver vs -user-or-group-name monitor -application ssh -authentication-method password -second-authentication-method none -role vsadmin
