security login role prepare-to-downgrade
- PDF of this doc site
Creating your file...
Your file is ready
Update role configurations so that they are compatible with earlier releases of Data ONTAP
The security login role prepare-to-downgrade
command restores predefined roles of all Vservers earlier than Data ONTAP 8.3.2. You must run this command in advanced privilege mode when prompted to do so during the release downgrade.
The following command restores predefined roles of all Vservers earlier than Data ONTAP 8.3.2.
cluster1::*> security login role prepare-to-downgrade
