ONTAP commands
security login role prepare-to-downgrade
Update role configurations so that they are compatible with earlier releases of Data ONTAP
The security login role prepare-to-downgrade command restores predefined roles of all Vservers earlier than ONTAP 8.3.2. You must run this command in advanced privilege mode when prompted to do so during the release downgrade.
The following command restores predefined roles of all Vservers earlier than ONTAP 8.3.2.
cluster1::*> security login role prepare-to-downgrade
