security login rest-role modify
Modify a REST access control role
The security login rest-role modify command modifies a Representational State Transfer (REST) access-control role.
-vserver <vserver name>- Vserver-
This optionally specifies the Vserver name associated with the REST role.
 -role <text>- Role Name-
This specifies the REST role that is to be modified.
 -api <text>- API Path-
This specifies the Application Programming Interface (API) to which the REST role has access. This API can be a resource-qualified endpoint. Currently, the only supported resource-qualified endpoints are the following:
Snapshots APIs
/api/storage/volumes/{volume.uuid}/snapshots -
File System Analytics APIs
/api/storage/volumes/{volume.uuid}/files -
/api/storage/volumes/{volume.uuid}/top-metrics/clients -
/api/storage/volumes/{volume.uuid}/top-metrics/directories -
/api/storage/volumes/{volume.uuid}/top-metrics/files -
/api/storage/volumes/{volume.uuid}/top-metrics/users -
/api/svm/svms/{svm.uuid}/top-metrics/clients -
/api/svm/svms/{svm.uuid}/top-metrics/directories -
/api/svm/svms/{svm.uuid}/top-metrics/files -
/api/svm/svms/{svm.uuid}/top-metrics/users
In the above APIs, wildcard character
*could be used in place of{volume.uuid}or{svm.uuid}to denoteallvolumes orallSVMs, depending upon whether the REST endpoint references volumes or SVMs. -
 [-access {none|readonly|read_create|read_modify|read_create_modify|all}]- Access Level-
This specifies a new access level for the REST role. Possible access level settings are
none,readonly,read_create,read_modify,read_create_modifyandall.
The following command modifies a REST access-control role with the role name readonly and the API /api/storage/volumes to have the access level readonly for Vserver vs.example.com :
cluster1::> security login rest-role modify -role readonly -api "/api/storage/volumes" -access readonly -vserver vs.example.com cluster1::>
The following command modifies a REST access-control role with the role name rest_role1 and the API /api/snapmirror/policies to have the access level read_create for Vserver cluster1.example.com :
cluster1::> security login rest-role modify -role rest_role1 -api "/api/snapmirror/policies" -access read_create -vserver cluster1.example.com cluster1::>
The following command modifies a REST access-control role with the role name vs1_role and the resource-qualified endpoint /api/storage/volumes/*/snapshots to have the access level readonly for Vserver vs1.example.com :
cluster1::> security login rest-role modify -role vs1_role -api "/api/storage/volumes/*/snapshots" -access readonly -vserver vs1.example.com cluster1::>
The following command modifies a REST access-control role with the role name vs2_role and the resource-qualified endpoint /api/storage/volumes/4d383f47-1d40-11ec-81af-005056bb3eae/top-metrics/users to have the access level none for Vserver vs2.example.com :
cluster1::> security login rest-role modify -role vs2_role -api "/api/storage/volumes/4d383f47-1d40-11ec-81af-005056bb3eae/top-metrics/users" -access none -vserver vs2.example.com cluster1::>
The following command modifies a REST access-control role with the role name vs3_role and the resource-qualified endpoint /api/svm/svms/6dfeb406-9a16-11ec-819e-005056bb1a7c/top-metrics/files to have the access level read_modify for Vserver vs3.example.com :
cluster1::> security login rest-role modify -role vs3_role -api "/api/svm/svms/6dfeb406-9a16-11ec-819e-005056bb1a7c/top-metrics/files" -access read_modify -vserver vs3.example.com cluster1::>
The following command modifies a REST access-control role with the role name vs3_role2 and the wildcard resource-qualified endpoint /api/svm/svms/*/top-metrics/clients to have the access level readonly for Vserver vs3.example.com :
cluster1::> security login rest-role modify -role vs3_role2 -api "/api/svm/svms/*/top-metrics/clients" -access readonly -vserver vs3.example.com cluster1::>
