security key-manager show-key-store
Displays the configured key manager key stores.
This command displays the list of configured key managers.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, then the command will list the key manager configured for the given Vserver.
 [-key-store <Key Store>]- Key Store-
If you specify this parameter, then the command displays only the vservers that have the given key-store configured.
 [-state <Key Store state>]- Key Store State-
If you specify this parameter, then the command displays only the vservers that have the given state configured.
 [-keystore-type <Key Store Type>]- Key Store Type (Azure/AWS etc)-
If you specify this parameter, then the command displays only the vservers that have the given keystore-type configured. This parameter is used to specify a particular type of external key manager. If this parameter is specified and 'key-store' is provided as 'onboard', the "security key-manager show-key-store" command will not return any entries.
 [-policy <text>]- Key Manager Policy Name-
If you specify this parameter, then the command displays only the vservers that have the given policy.
The following example shows all configured key managers in the cluster. In the example, the admin vserver has the Onboard Key Manager configured and the data vserver "datavs1" has external key management configured:
cluster-1::> security key-manager show-key-store Vserver Key Store Key Store Type ---------------------- --------- -------------- cluster-1 onboard - datavs1 external AKV
