system controller fru show-manufacturing-info
Display manufacturing information of FRUs
The system controller fru show-manufacturing-info command displays manufacturing information for field replaceable units (FRUs) installed in the system. The information includes FRU-description, serial number, part number, and revision number. To display more details, use the -instance parameter.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
Displays detailed information about the installed FRUs in the system.
- [-node {<nodename>|local}]- Node
Selects a specific node's installed FRUs.
- [-system-sn <text>]- System Serial Number
Selects information about installed FRUs with the specified system serial number.
- [-model-name <text>]- Model Name
Selects information about installed FRUs with the specified model name.
- [-system-id <text>]- System ID
Selects information about installed FRUs with the specified system ID.
- [-kernel-version <text>]- Kernel Version
Selects information about installed FRUs with the specified kernel version.
- [-firmware-release <text>]- Firmware Release
Selects information about installed FRUs with the specified firmware release.
- [-description <text>]- FRU Description
Selects information about installed FRUs with the specified FRU description.
- [-vendor-id <text>]- FRU Vendor ID
Selects information about the FRU with the vendor identification.
- [-serial-number <text>]- FRU Serial Number
Selects information about the FRU with the specified serial number.
- [-part-number <text>]- FRU Part Number
Selects information about the FRU with the specified part number.
- [-revision <text>]- FRU Revision of Part Number
Selects information about the FRU with the specified revision.
- [-manufacturer <text>]- FRU Manufacturer
Selects information about the FRU with the specified manufacturer.
- [-manufacture-date <text>]- FRU Manufacturing Date
Selects information about the FRU with the specified manufacture date.
- [-product-id <text>]- FRU Product Identifier
Selects information about the FRU with the specified product ID.
- [-firmware-version <text>]- FRU Firmware Version
Selects information about the FRU with the specified firmware version.
The following example displays all installed FRUs in the system:
cluster1::> system controller fru show-manufacturing-info
Node: platsw-lodi-1-01
System Serial Number: 791541000047
          Model Name: FAS9040
           System ID: 0537024373
    Firmware release: 10.0X18
      Kernel Version: NetApp Release sysMman_3887886_1608151712: Mon Aug 15
                      15:54:00 PDT 2016
FRU Description          FRU Serial Number        FRU Part Number    FRU Rev.
Mother Board             031537000390             111-02419          40
Chassis                  031536000252             111-02392          40
DIMM-1                   CE-01-1510-02A8DC73      SHB722G4LML23P2-SB -
DIMM-3                   CE-01-1510-02A8DCCC      SHB722G4LML23P2-SB -
DIMM-8                   CE-01-1510-02A8DE54      SHB722G4LML23P2-SB -
DIMM-9                   CE-01-1510-02A8DE1C      SHB722G4LML23P2-SB -
DIMM-11                  CE-01-1510-02A8DF42      SHB722G4LML23P2-SB -
DIMM-16                  CE-01-1510-02A8DD9B      SHB722G4LML23P2-SB -
FAN1                     031534001263             441-00058          40
FAN2                     031534001292             441-00058          40
FAN3                     031534001213             441-00058          40
PSU1                     PSD092153200591          114-00146          40
PSU3                     PSD092153200700          114-00146          40
mSATA boot0              1439100B02C3             -                  MU03
1/10 Gigabit Ethernet Controller IX4-T 031538000121 111-02399        40
QLogic 8324 10-Gigabit Ethernet Controller 031535000664 111-02397    40
NVRAM10                  031537000846             111-02394          40
NVRAM10 BATT             31534000932              NetApp, Inc.       111-02591
NVRAM10 DIMM             CE-01-1510-02A8DC03      SHB722G4LML23P2-SB -
PMC-Sierra PM8072 (111-02396) 031537000246        111-02396          41
PMC-Sierra PM8072 (111-02396) 031537000179        111-02396          41
Disk Serial Number       PNHH1J0B                 X421_HCOBD450A10   -
Disk Serial Number       PNHH2BKB                 X421_HCOBD450A10   -
Disk Serial Number       PNHJPZ8B                 X421_HCOBD450A10   -
Disk Serial Number       PNHG6SKB                 X421_HCOBD450A10   -
Disk Serial Number       PNHKJYTB                 X421_HCOBD450A10   -
Disk Serial Number       PNHSVMEY                 X421_HCOBD450A10   -
Disk Serial Number       PNHT8KWY                 X421_HCOBD450A10   -
Disk Serial Number       PNHSVL0Y                 X421_HCOBD450A10   -
Disk Serial Number       PNHG5RHB                 X421_HCOBD450A10   -
Disk Serial Number       PNHEXLWB                 X421_HCOBD450A10   -
Disk Serial Number       PNHT8LJY                 X421_HCOBD450A10   -
Disk Serial Number       PNHSVKZY                 X421_HCOBD450A10   -
DS2246                   6000113106               0190               -
DS2246-Pwr-Supply        XXT111825308             114-00065+A0       9C
DS2246-Pwr-Supply        XXT111825314             114-00065+A0       9C
DS2246-MODULE            8000675532               111-00690+A3       23
DS2246-MODULE            8000751790               111-00690+A3       23
DS2246-CABLE             512130075                112-00430+A0       -
DS2246-CABLE             -                        -                  -
DS2246-CABLE             512130118                112-00430+A0       -
DS2246-CABLE             -                        -                  -
49 entries were displayed.
 PDFs
PDFs
