ONTAP commands
system snmp prepare-to-downgrade
Change SNMP configuration to the default settings for releases earlier than Data ONTAP 9.3.0
The system snmp prepare-to-downgrade command prepares the SNMP subsystem for a downgrade or a revert. More specifically, it prepares the SNMPv3 client feature for a downgrade or a revert. It deletes all storage switches that were explicitly added for monitoring and are using SNMPv3 as the underlying protocol. It also deletes any cluster switches that are using SNMPv3 for monitoring. Finally, it deletes any remote switch SNMPv3 users configured in ONTAP.
The following command prepares the SNMP subsystem for a downgrade or a revert, within a cluster named cluster1:
cluster1::*> system snmp prepare-to-downgrade
