security multi-admin-verify modify
Modify multi-admin-verify settings
The security multi-admin-verify modify command is used to modify the Multi-Admin-Verify global settings.
- [-approval-groups <text>,…]- List of Global Approval Groups
This specifies the list of global approval groups which are inherited by the rule if the approval-groups is not provided for the rule. The default value is an empty list. The approval-groups should be defined to enable multi-admin verification. The supplied value replaces the list. You can create an approval-group by using the security multi-admin-verify approval-group create command.
- [-required-approvers <integer>]- Number of Required Approvers
This specifies the required number of approvers to approve the request which is inherited by the rule if required-approvers is not provided for the rule. The default and minimum number of required approvers is 1.
- [-enabled {true|false}]- Is Multi-Admin-Verify Enabled
This specifies the current state. Multi-admin verification is not required to enable the feature. However, it is required to disable the feature. The feature is disabled by default and the value is set to false.
- [-execution-expiry <[<integer>h][<integer>m][<integer>s]>]- Execution Expiry
This is the amount of time that the authorized users have after a request is approved to execute the requested operation before the request expires. The default value is one hour ( 1h), the minimum supported value is one second (1s), and the maximum supported value is 14 days (14d).
- [-approval-expiry <[<integer>h][<integer>m][<integer>s]>]- Approval Expiry
This is the amount of time that the approvers have after a new execution request is submitted to approve or disapprove the request before the request expires. The default value is one hour ( 1h), the minimum supported value is one second (1s), and the maximum supported value is 14 days (14d).
This command changes the approval groups:
cluster1::> security multi-admin-verify modify -approval-groups group1, group2
This command changes the required number of approvers:
cluster1::> security multi-admin-verify modify -required-approvers 3
This command enables the feature. The default is false (disabled):
cluster1::> security multi-admin-verify modify -enabled true
This command changes the execution expiry:
cluster1::> security multi-admin-verify modify -execution-expiry 14d
This command changes the approval expiry:
cluster1::> security multi-admin-verify modify -approval-expiry 48h
 PDFs
PDFs
