lun persistent-reservation show
Display the current reservation information for a given LUN
Displays reservation information for a specified LUN in a Vserver. Unlike other show commands, the user must specify the LUN.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. -vserver <Vserver Name>- Vserver Name (privilege: advanced)-
Specifies the Vserver.
-path <path>- LUN Path (privilege: advanced) -
Specifies the path of the LUN. Examples of correct LUN paths are
/vol/vol1/lun1and/vol/vol1/qtree1/lun1. - |
-volume <volume name>- Volume Name (privilege: advanced) -
Specifies the volume.
-lun <text>- LUN Name (privilege: advanced)-
Specifies the name of the LUN.
[-qtree <qtree name>]- Qtree Name (privilege: advanced) }-
Specifies the qtree.
[-scsi-revision {scsi2|scsi3}]- SCSI Revision (privilege: advanced)-
Selects the reservations that match this parameter value.
[-entry-type {reservation|registration}]- Reservation or Registration (privilege: advanced)-
[-protocol {fcp|iscsi}]- Protocol (privilege: advanced)-
[-reservation-key <text>]- Reservation Key (privilege: advanced)-
[-reservation-type-code <text>]- Reservation Type (privilege: advanced)-
Selects the reservations that match this parameter value. The possible values for SCSI-3 reservations are:
write exclusive
exclusive access
write exclusive registrants only
exclusive access registrants only
write exclusive all registrants
exclusive access all registrants
and for SCSI-2 are:
regular
third party
[-initiator-name <text>]- Initiator Name (privilege: advanced)-
[-aptpl {true|false}]- Persist Through Power Loss (privilege: advanced)-
Selects the reservations that match this parameter value. If
true, the reservation will be preserved over a power loss. Iffalse, it will not. This value is for SCSI-3 reservations only. [-target-wwpn <text>]- FCP Target WWPN (privilege: advanced)-
Selects the reservations that match the specified World Wide Port Name (WWPN).
[-isid <text>]- Initiator Session ID (privilege: advanced)-
[-tpgroup-tag <integer>]- TPGroup Tag (privilege: advanced)-
Selects the reservations that match the specified target portal group tag. The tag identifies the tpgroup the reservation was made over.
[-third-party-initiator-name <text>]- Third Party Initiator Name (privilege: advanced)-
Selects the reservations that match this parameter value (the initiator name that the reservation was made for). This is specific to third party reservation types, which is indicated by reservation-type-code.
cluster1::*> lun persistent-reservation show -vserver vs_1 /vol/vol_1/lun_1
Key Protocol Type Initiator Name
APTPL: true
a0:00:00:00:00:00:00:01 iscsi write exclusive iqn.1993-08.org.debian:01:fa752b8a5a3a
a0:00:00:00:00:00:00:01 iscsi - iqn.1993-08.org.debian:01:fa752b8a5a3a
2 entries were displayed.
The example above displays the current reservations for lun_1 on Vsever vs_1.
