lun persistent-reservation show
Display the current reservation information for a given LUN
Displays reservation information for a specified LUN in a Vserver. Unlike other show commands, the user must specify the LUN.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. -vserver <Vserver Name>- Vserver Name (privilege: advanced)-
Specifies the Vserver.
-path <path>- LUN Path (privilege: advanced) -
Specifies the path of the LUN. Examples of correct LUN paths:
/vol/vol1/lun1and/vol/vol1/qtree1/lun1 - |
-volume <volume name>- Volume Name (privilege: advanced) -
Specifies the volume.
 -lun <text>- LUN Name (privilege: advanced)-
Specifies the name of the LUN.
 [-qtree <qtree name>]- Qtree Name (privilege: advanced) }-
Specifies the qtree.
 [-scsi-revision {scsi2|scsi3}]- SCSI Revision (privilege: advanced)-
Selects the reservations that match this parameter value.
 [-entry-type {reservation|registration}]- Reservation or Registration (privilege: advanced)-
 [-protocol {fcp|iscsi}]- Protocol (privilege: advanced)-
 [-reservation-key <text>]- Reservation Key (privilege: advanced)-
 [-reservation-type-code <text>]- Reservation Type (privilege: advanced)-
Selects the reservations that match this parameter value. The possible values for SCSI-3 reservations are:
write exclusive
exclusive access
write exclusive registrants only
exclusive access registrants only
write exclusive all registrants
exclusive access all registrants
and for SCSI-2 are:
regular
third party
 [-initiator-name <text>]- Initiator Name (privilege: advanced)-
 [-aptpl {true|false}]- Persist Through Power Loss (privilege: advanced)-
Selects the reservations that match this parameter value. If
true, the reservation will be preserved over a power loss. Iffalse, it will not. This value is for SCSI-3 reservations only. [-rtpid <integer>]- Relative Target Port ID (privilege: advanced)-
Selects the reservations that match the specified Relative Target Port ID (RTPID). This applies to SCSI-3 reservations only.
 [-target-wwpn <text>]- FCP Target WWPN (privilege: advanced)-
Selects the reservations that match the specified World Wide Port Name (WWPN).
 [-isid <text>]- Initiator Session ID (privilege: advanced)-
 [-tpgroup-tag <integer>]- TPGroup Tag (privilege: advanced)-
Selects the reservations that match the specified target portal group tag. The tag identifies the tpgroup the reservation was made over.
 [-third-party-initiator-name <text>]- Third Party Initiator Name (privilege: advanced)-
Selects the reservations that match this parameter value (the initiator name that the reservation was made for). This is specific to third party reservation types, which is indicated by reservation-type-code.
 [-zrto-status {none|primary-out-of-sync|primary-in-sync|secondary-out-of-sync|secondary-in-sync}]- ZRTO Status (privilege: advanced)-
cluster1::*> lun persistent-reservation show -vserver vs_1 /vol/vol_1/lun_1
     Key                     Protocol Type              Initiator Name
     APTPL: true
     a0:00:00:00:00:00:00:01 iscsi    write exclusive   iqn.1993-08.org.debian:01:fa752b8a5a3a
     a0:00:00:00:00:00:00:01 iscsi    -                 iqn.1993-08.org.debian:01:fa752b8a5a3a
     2 entries were displayed.
The example above displays the current reservations for lun_1 on Vserver vs_1.
