lun persistent-reservation show
Display the current reservation information for a given LUN
Displays reservation information for a specified LUN in a Vserver. Unlike other show commands, the user must specify the LUN.
{ [-fields <fieldname>,…​]
| [-instance ] }
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
{ -path <path> - LUN Path
Specifies the path of the LUN. Examples of correct LUN paths are /vol/vol1/lun1 and /vol/vol1/qtree1/lun1 .
| -volume <volume name> - Volume Name
Specifies the volume.
-lun <text> - LUN Name
Specifies the name of the LUN.
[-qtree <qtree name>] - Qtree Name }
Specifies the qtree.
[-scsi-revision {scsi2|scsi3}] - SCSI Revision
Selects the reservations that match this parameter value.
[-entry-type {reservation|registration}] - Reservation or Registration
[-protocol {fcp|iscsi}] - Protocol
[-reservation-key <text>] - Reservation Key
[-reservation-type-code <text>] - Reservation Type
Selects the reservations that match this parameter value. The possible values for SCSI-3 reservations are:
  • write exclusive
  • exclusive access
  • write exclusive registrants only
  • exclusive access registrants only
  • write exclusive all registrants
  • exclusive access all registrants
and for SCSI-2 are:
  • regular
  • third party
[-initiator-name <text>] - Initiator Name
[-aptpl {true|false}] - Persist Through Power Loss
Selects the reservations that match this parameter value. If true , the reservation will be preserved over a power loss. If false , it will not. This value is for SCSI-3 reservations only.
[-target-wwpn <text>] - FCP Target WWPN
Selects the reservations that match the specified World Wide Port Name (WWPN).
[-isid <text>] - Initiator Session ID
[-tpgroup-tag <integer>] - TPGroup Tag
Selects the reservations that match the specified target portal group tag. The tag identifies the tpgroup the reservation was made over.
[-third-party-initiator-name <text>] - Third Party Initiator Name
Selects the reservations that match this parameter value (the initiator name that the reservation was made for). This is specific to third party reservation types, which is indicated by reservation-type-code.
cluster1::*> lun persistent-reservation show -vserver vs_1 /vol/vol_1/lun_1
     Key                     Protocol Type              Initiator Name
     APTPL: true
     a0:00:00:00:00:00:00:01 iscsi    write exclusive   iqn.1993-08.org.debian:01:fa752b8a5a3a
     a0:00:00:00:00:00:00:01 iscsi    -                 iqn.1993-08.org.debian:01:fa752b8a5a3a
     2 entries were displayed.
The example above displays the current reservations for lun_1 on Vsever vs_1.
