ONTAP commands
lun persistent-reservation show
Display the current reservation information for a given LUN
Displays reservation information for a specified LUN in a Vserver. Unlike other show commands, the user must specify the LUN.
{ [-fields <fieldname>,…​]
| [-instance ] }
-vserver <Vserver Name> - Vserver Name (privilege: advanced)
Specifies the Vserver.
{ -path <path> - LUN Path (privilege: advanced)
Specifies the path of the LUN. Examples of correct LUN paths are /vol/vol1/lun1 and /vol/vol1/qtree1/lun1 .
| -volume <volume name> - Volume Name (privilege: advanced)
Specifies the volume.
-lun <text> - LUN Name (privilege: advanced)
Specifies the name of the LUN.
[-qtree <qtree name>] - Qtree Name (privilege: advanced) }
Specifies the qtree.
[-scsi-revision {scsi2|scsi3}] - SCSI Revision (privilege: advanced)
Selects the reservations that match this parameter value.
[-entry-type {reservation|registration}] - Reservation or Registration (privilege: advanced)
[-protocol {fcp|iscsi}] - Protocol (privilege: advanced)
[-reservation-key <text>] - Reservation Key (privilege: advanced)
[-reservation-type-code <text>] - Reservation Type (privilege: advanced)
Selects the reservations that match this parameter value. The possible values for SCSI-3 reservations are:
  • write exclusive
  • exclusive access
  • write exclusive registrants only
  • exclusive access registrants only
  • write exclusive all registrants
  • exclusive access all registrants
and for SCSI-2 are:
  • regular
  • third party
[-initiator-name <text>] - Initiator Name (privilege: advanced)
[-aptpl {true|false}] - Persist Through Power Loss (privilege: advanced)
Selects the reservations that match this parameter value. If true , the reservation will be preserved over a power loss. If false , it will not. This value is for SCSI-3 reservations only.
[-target-wwpn <text>] - FCP Target WWPN (privilege: advanced)
Selects the reservations that match the specified World Wide Port Name (WWPN).
[-isid <text>] - Initiator Session ID (privilege: advanced)
[-tpgroup-tag <integer>] - TPGroup Tag (privilege: advanced)
Selects the reservations that match the specified target portal group tag. The tag identifies the tpgroup the reservation was made over.
[-third-party-initiator-name <text>] - Third Party Initiator Name (privilege: advanced)
Selects the reservations that match this parameter value (the initiator name that the reservation was made for). This is specific to third party reservation types, which is indicated by reservation-type-code.
cluster1::*> lun persistent-reservation show -vserver vs_1 /vol/vol_1/lun_1
     Key                     Protocol Type              Initiator Name
     APTPL: true
     a0:00:00:00:00:00:00:01 iscsi    write exclusive   iqn.1993-08.org.debian:01:fa752b8a5a3a
     a0:00:00:00:00:00:00:01 iscsi    -                 iqn.1993-08.org.debian:01:fa752b8a5a3a
     2 entries were displayed.
The example above displays the current reservations for lun_1 on Vsever vs_1.
