network port broadcast-domain split
Splits a layer 2 broadcast domain into two layer 2 broadcast domains.
Splits ports from a broadcast domain into a new broadcast domain.
The following restrictions apply to this command:
If the ports are in a failover group, all ports in the failover group must be provided. Use network interface failover-groups show to see which ports are in failover groups.
If the ports have LIFs associated with them, the LIFs cannot be part of a subnet's ranges and the LIF's
curr-portandhome-portmust both be provided. Use network interface show-fieldssubnet-name,home-node,home-port,curr-node,curr-portto see which ports have LIFs associated with them and whether the LIFs are part of a subnet's ranges. Use network subnet remove-ranges with the LIF's IP address and-force-update-lif-associationsset totrueto remove the LIF's association with a subnet.
-ipspace <IPspace>- IPspace Name-
The IPspace of the broadcast domain.
 -broadcast-domain <Broadcast Domain>- Layer 2 Broadcast Domain-
The broadcast domain to split.
 -new-broadcast-domain <Broadcast Domain>- New Layer 2 Broadcast Domain Name-
The new broadcast domain.
 -ports [node>:<port],…- List of Ports-
The ports to be split from this broadcast domain.
The following example splits port "e0d" on node "cluster1-1" and port "e0d" on node "cluster1-2" from broadcast domain "bd-mgmt" in IPspace "Default" to broadcast domain "bd-data".
cluster1::> network port broadcast-domain split -ipspace Default -broadcast-domain bd-mgmt -new-broadcast-domain bd-data -ports cluster1-1:e0d, cluster1-2:e0d
