storage aggregate object-store unmirror
Remove the second object store from a mirrored FabricPool
The storage aggregate object-store unmirror command detaches a second object store from a mirrored FabricPool. This command verifies whether the primary object store is accessible through the intercluster LIF from both the node on which the aggregate is present and from its high-availability (HA) partner node. The command fails if the primary object store is not available.
-aggregate <text> - Name of the Aggregate
This parameter specifies the aggregate from which the mirrored object store must be removed.
The following example shows how to unmirror a mirrored FabricPool aggr1:
cluster1::>storage aggregate object-store unmirror -aggregate aggr1
