ONTAP commands
network ndp default-router show
Display default routers
The network ndp default-router show command displays Neighbor Discovery Protocol (NDP) default routers learned on a specified port.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node (privilege: advanced)
Displays the NDP default routers from the specified node.
[-ipspace <IPspace>] - IPspace name (privilege: advanced)
Displays the NDP default routers from the specified IPspace.
[-port {<netport>|<ifgrp>}] - Port (privilege: advanced)
Displays the NDP default routers from the specified port.
[-router-addr <IP Address>] - Router Address (privilege: advanced)
Displays the default routers that have the specified IPv6 addresses.
[-flag {none|managed-address-DHCPv6|other-DHCPv6}] - Flag (privilege: advanced)
Displays the default routers that have the specified flag. The flag indicates whether addresses are available via DHCPv6 or other configuration information is available via DHCPv6.
[-expire-time {[<integer>d][<integer>h][<integer>m][<integer>s]|never|expired}] - Expire Time (privilege: advanced)
Displays the default routers that have the specified expire time.
The following example displays NDP default routers on local port e0f.
cluster1::*> network ndp default-router show -port e0f -node local
Node: node1
IPspace: Default
Port     Router Address             Flag            Expire Time
e0f      fe80::5:73ff:fea0:107      none            0d0h23m9s
