network ndp default-router show
Display default routers
The network ndp default-router show
command displays Neighbor Discovery Protocol (NDP) default routers learned on a specified port.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node (privilege: advanced)-
Displays the NDP default routers from the specified node.
[-ipspace <IPspace>]
- IPspace name (privilege: advanced)-
Displays the NDP default routers from the specified IPspace.
[-port {<netport>|<ifgrp>}]
- Port (privilege: advanced)-
Displays the NDP default routers from the specified port.
[-router-addr <IP Address>]
- Router Address (privilege: advanced)-
Displays the default routers that have the specified IPv6 addresses.
[-flag {none|managed-address-DHCPv6|other-DHCPv6}]
- Flag (privilege: advanced)-
Displays the default routers that have the specified flag. The flag indicates whether addresses are available via DHCPv6 or other configuration information is available via DHCPv6.
[-expire-time {[<integer>d][<integer>h][<integer>m][<integer>s]|never|expired}]
- Expire Time (privilege: advanced)-
Displays the default routers that have the specified expire time.
The following example displays NDP default routers on local port e0f.
cluster1::*> network ndp default-router show -port e0f -node local Node: node1 IPspace: Default Port Router Address Flag Expire Time -------- -------------------------- -------------- -------------- e0f fe80::5:73ff:fea0:107 none 0d0h23m9s
