ONTAP 9.12.1 commands
snapmirror object-store config create
Define the configuration for a SnapMirror object store
The snapmirror object-store config create command is used by a cluster administrator to tell Data ONTAP how to connect to an object store. Following pre-requisites must be met before creating an object store configuration in Data ONTAP.
  • A valid data bucket or container must be created with the object store provider. This assumes that the user has valid account credentials with the object store provider to access the data bucket.
  • The Data ONTAP node must be able to connect to the object store. This includes
  • Fast, reliable connectivity to the object store.
  • An inter-cluster LIF (Logical Interface) must be configured on the cluster.
  • If SSL/TLS authentication is required, then valid certificates must be installed.
An object-store configuration once created must not be reassociated with a different object-store or container. See snapmirror object-store config modify command for more information.
-vserver <vserver name> - Vserver Name
This parameter specifies the vserver on which the object store configuration needs to be created.
-object-store-name <text> - Object Store Configuration Name
This parameter specifies the name that will be used to identify the object store configuration. The name can contain the following characters: "", "-", A-Z, a-z, and 0-9. The first character must be one of the following: "", A-Z, or a-z.
-usage {data|metadata} - Object Store Use
This parameter specifies the usage for an object store configuration
-provider-type <providerType> - Type of the Object Store Provider
This parameter specifies the type of object store provider that will be attached to the aggregate. Valid options are: AWS_S3 (Amazon S3 storage), Azure_Cloud (Microsoft Azure Cloud), SGWS (StorageGrid WebScale), IBM_COS (IBM Cloud Object Storage), AliCloud (Alibaba Cloud Object Storage Service), GoogleCloud (Google Cloud Storage) and ONTAP_S3.
-server <Remote InetAddress> - Fully Qualified Domain Name of the Object Store Server
This parameter specifies the Fully Qualified Domain Name (FQDN) of the remote object store server. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3-<region>.amazonaws.com, for example, s3-us-west-2.amazonaws.com. The region of the server and the bucket must match. For more information on AWS regions, refer to 'Amazon documentation on AWS regions and endpoints'. For Azure, if the -server is a "blob.core.windows.net" or a "blob.core.usgovcloudapi.net", then a value of -azure-account followed by a period will be added in front of the server.
[-is-ssl-enabled {true|false}] - Is SSL/TLS Enabled
This parameter indicates whether a secured SSL/TLS connection will be used during data access to the object store. The default value is true .
[-port <integer>] - Port Number of the Object Store
This parameter specifies the port number on the remote server that Data ONTAP will use while establishing connection to the object store.
-container-name <text> - Data Bucket/Container Name
This parameter specifies the data bucket or container that will be used for read and write operations.
Note This name cannot be modified once a configuration is created.
[-access-key <text>] - Access Key ID for S3 Compatible Provider Types
This parameter specifies the access key (access key ID) required to authorize requests to the AWS S3, SGWS, IBM COS object stores and ONTAP_S3. For an Azure object store see -azure-account .
[-ipspace <IPspace>] - IPspace to Use in Order to Reach the Object Store
This optional parameter specifies the IPspace to use to connect to the object store. Default value: Default .
[-use-iam-role {true|false}] - (DEPRECATED)-Use IAM Role for AWS Cloud Volumes ONTAP
This optional parameter is depricated. Please use -auth-type instead. Note, that -auth-type EC2-IAM is an equivalent of -use-iam-role true , and -auth-type key is an equivalent of -use-iam-role false .
[-secret-password <text>] - Secret Access Key for S3 Compatible Provider Types
This parameter specifies the password (secret access key) to authenticate requests to the AWS S3, SGWS, IBM COS object stores and ONTAP_S3. If the -access-key is specified but the -secret-password is not, then one will be asked to enter the -secret-password without echoing the input.
[-is-certificate-validation-enabled {true|false}] - Is SSL/TLS Certificate Validation Enabled
This parameter indicates whether an SSL/TLS certificate of an object store server is validated whenever an SSL/TLS connection to an object store server is established. This parameter is only applicable when is-ssl-enabled is true . The default value is true . It is recommended to use the default value to make sure that Data ONTAP connects to a trusted object store server, otherwise identities of an object store server are not verified.
[-azure-account <text>] - Azure Account
This parameter specifies the account required to authorize requests to the Azure object store. For other object store providers see access-key.
Note The value of this field cannot be modified once a configuration is created.
[-ask-azure-private-key {true|false}] - Ask to Enter the Azure Access Key without Echoing
If this parameter is true then one will be asked to enter -azure-private-key without echoing the input. Default value: true .
[-azure-private-key <text>] - Azure Access Key
This parameter specifies the access key required to authenticate requests to the Azure object store. See also ask-azure-private-key . For other object store providers see -secret-password .
[-server-side-encryption {none | SSE-S3}] - Encryption of Data at Rest by the Object Store Server (privilege: advanced)
This parameter specifies if AWS or other S3 compatible object store server must encrypt data at rest. The available choices depend on provider-type. none encryption (no encryption required) is supported by all types of S3 (non-Azure) object store servers. SSE-S3 encryption is supported by and is a default for all types of S3 (non-Azure) object store servers except ONTAP_S3. This is an advanced property. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level.
[-url-style {path-style | virtual-hosted-style}] - URL Style Used to Access S3 Bucket
This parameter specifies the URL style used to access S3 bucket. This option is only available for non-Azure object store providers. The available choices and default value depend on provider-type.
