san config enable-san-optimized
Enable the All SAN Array personality for the cluster
The san config enable-san-optimized command converts the cluster to an All SAN Array. Conversion is a one-way, irreversible process. All SAN Array does not support NAS protocols. Prior to conversion, remove all NAS services and LIFs.
The following example converts the cluster to an All SAN Array.
cluster1::*> san config enable-san-optimized
