ONTAP 9.12.1 commands
network ipspace delete
Delete an IPspace
Delete an IPspace that contains no ports or Vservers.
-ipspace <IPspace> - IPspace name
The name of the IPspace to be deleted. If the IPspace is associated with one or more logical-interfaces, you must delete them before you can delete the IPspace.
The following example deletes the IPspace "ips1".
cluster1::> network ipspace delete -ipspace ips1
