security multi-admin-verify approval-group modify
Modify an Approval Group
The security multi-admin-verify approval-group modify command is used to modify attributes of an approval group.
-vserver <vserver>- Vserver-
This specifies the Vserver name to which the approval group is associated with. This is an optional parameter. This parameter defaults to a Cluster server and supports only Cluster servers.
-name <text>- Group Name-
This specifies the name of an approval group.
[-approvers <text>,…]- Approvers-
This specifies the list of ONTAP users that are part of the approval group. Each specified user must belong to the specified Vserver.
[-email <mail address>,…]- Email Addresses-
This specifies the email addresses that are notified when a request is created, approved, vetoed, or executed.
This command changes the approvers:
cluster1::> security multi-admin-verify approval-group modify -name group1 -approvers admin1
