metrocluster transition show-mode
Display the transition mode
The metrocluster transition show-mode
command is used to display the current setting of transition.
The following example shows the output of the command when transition is not enabled:
clusA::> metrocluster transition show-mode Transition Mode -------------------------- not-enabled
The following example shows the output of the command when non-disruptive transition is enabled:
clusA::> metrocluster transition show-mode Transition Mode -------------------------- non-disruptive
The following example shows the output of the command when disruptive transition is enabled:
clusA::> metrocluster transition show-mode Transition Mode -------------------------- disruptive
