ONTAP commands
metrocluster transition show-mode
Display the transition mode
The metrocluster transition show-mode command is used to display the current setting of transition.
The following example shows the output of the command when transition is not enabled:
clusA::> metrocluster transition show-mode
 Transition Mode
 not-enabled
The following example shows the output of the command when non-disruptive transition is enabled:
 Transition Mode
 non-disruptive
The following example shows the output of the command when disruptive transition is enabled:
 Transition Mode
 disruptive
