network tuning tcp show
Show TCP tuning options
This command displays the current state of the TCP tuning options for the given node.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
Displays all TCP tuning options.
- [-node {<nodename>|local}]- Node
Specifies the node for which the TCP tuninng options will be displayed.
- [-is-path-mtu-discovery-enabled {true|false}]- Path MTU discovery enabled
Displays all entries that match the "is-path-mtu-discovery-enabled" value.
- [-is-rfc3465-enabled {true|false}]- RFC3465 enabled
Displays all entries that match the "is-rfc3465-enabled" value.
- [-max-cwnd-increment <integer>]- Maximum congestion window segments incrementation
Displays all entries that match the "max-cwnd-increment" value.
- [-is-rfc3390-enabled {true|false}]- RFC3390 enabled
Displays all entries that match the "is-rfc3390-enabled" value.
- [-is-sack-enabled {true|false}]- SACK support enabled
Displays all entries that match the "is-sack-enabled" value.
cluster1::> network tuning tcp show
          Path MTU           Maximum                   Selective
Node      Discovery  RFC3465 Congestion Window RFC3390 Ack
          Enabled    Enabled Incrementation    Enabled Enabled
node1
          true       true    2                 true    true
 PDFs
PDFs
