network tuning tcp show
PDF of this doc site
Creating your file...
Show TCP tuning options
This command displays the current state of the TCP tuning options for the given node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
Displays all TCP tuning options.
[-node {<nodename>|local}]
- Node-
Specifies the node for which the TCP tuninng options will be displayed.
[-is-path-mtu-discovery-enabled {true|false}]
- Path MTU discovery enabled-
Displays all entries that match the "is-path-mtu-discovery-enabled" value.
[-is-rfc3465-enabled {true|false}]
- RFC3465 enabled-
Displays all entries that match the "is-rfc3465-enabled" value.
[-max-cwnd-increment <integer>]
- Maximum congestion window segments incrementation-
Displays all entries that match the "max-cwnd-increment" value.
[-is-rfc3390-enabled {true|false}]
- RFC3390 enabled-
Displays all entries that match the "is-rfc3390-enabled" value.
[-is-sack-enabled {true|false}]
- SACK support enabled-
Displays all entries that match the "is-sack-enabled" value.
cluster1::> network tuning tcp show Path MTU Maximum Selective Node Discovery RFC3465 Congestion Window RFC3390 Ack Enabled Enabled Incrementation Enabled Enabled --------- --------- ------- ----------------- ------- -------- node1 true true 2 true true
