network tuning tcp show
Show TCP tuning options
This command displays the current state of the TCP tuning options for the given node.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
Displays all TCP tuning options.
[-node {<nodename>|local}]- Node-
Specifies the node for which the TCP tuninng options will be displayed.
[-is-path-mtu-discovery-enabled {true|false}]- Path MTU discovery enabled-
Displays all entries that match the "is-path-mtu-discovery-enabled" value.
[-is-rfc3465-enabled {true|false}]- RFC3465 enabled-
Displays all entries that match the "is-rfc3465-enabled" value.
[-max-cwnd-increment <integer>]- Maximum congestion window segments incrementation-
Displays all entries that match the "max-cwnd-increment" value.
[-is-rfc3390-enabled {true|false}]- RFC3390 enabled-
Displays all entries that match the "is-rfc3390-enabled" value.
[-is-sack-enabled {true|false}]- SACK supoort enabled-
Displays all entries that match the "is-sack-enabled" value.
cluster1::> network tuning tcp show
Path MTU Maximum Selective
Node Discovery RFC3465 Congestion Window RFC3390 Ack
Enabled Enabled Incrementation Enabled Enabled
node1
true true 2 true true
