network tuning tcp show
Show TCP tuning options
This command displays the current state of the TCP tuning options for the given node.
{ [-fields <fieldname>,…​]
| [-instance ] }
Displays all TCP tuning options.
[-node {<nodename>|local}] - Node
Specifies the node for which the TCP tuninng options will be displayed.
[-is-path-mtu-discovery-enabled {true|false}] - Path MTU discovery enabled
Displays all entries that match the "is-path-mtu-discovery-enabled" value.
[-is-rfc3465-enabled {true|false}] - RFC3465 enabled
Displays all entries that match the "is-rfc3465-enabled" value.
[-max-cwnd-increment <integer>] - Maximum congestion window segments incrementation
Displays all entries that match the "max-cwnd-increment" value.
[-is-rfc3390-enabled {true|false}] - RFC3390 enabled
Displays all entries that match the "is-rfc3390-enabled" value.
[-is-sack-enabled {true|false}] - SACK supoort enabled
Displays all entries that match the "is-sack-enabled" value.
cluster1::> network tuning tcp show
          Path MTU           Maximum                   Selective
Node      Discovery  RFC3465 Congestion Window RFC3390 Ack
          Enabled    Enabled Incrementation    Enabled Enabled
node1
          true       true    2                 true    true
