system ha interconnect statistics clear-port
PDF of this doc site
Creating your file...
Your file is ready
Clear the high-availability interconnect port counters
The system ha interconnect statistics clear-port
command clears the high-availability interconnect device port statistics. This command is supported only on FAS2500 series and FAS8000 series nodes in the cluster.
To display the high-availability interconnect device port statistics, use the statistics show -object ic_hw_port_stats command. |
-node <nodename>
- Node (privilege: advanced)-
Selects the nodes that match this parameter value.
cluster1::*> system ha interconnect statistics clear-port -node ic-f8040-01
