volume flexcache prepopulate start
Prepopulate flexcache volume
The `volume flexcache prepopulate start` command is used to prepopulate a FlexCache volume with the data of given directory path(s) from the origin volume.
The FlexCache prepopulate job fails when the directories listed with the -path-list have one or more non-existing paths.
-cache-vserver <vserver name>
- Cache Vserver Name (privilege: advanced)-
This specifies the Vserver that has the FlexCache volume to be prepopulated.
-cache-volume <volume name>
- Cache Volume Name (privilege: advanced)-
This specifies the FlexCache volume which needs to be prepopulated.
-path-list <text>,…
- List of Paths (privilege: advanced)-
This specifies an array of directory names that need to be prepopulated in the FlexCache volume.
[-isRecursion {true|false}]
- Recursively populate (privilege: advanced)-
This specifies that the directories listed with the
-path-list
need to be recursively prepopulated in the-cache-volume
FlexCache volume.The default value is true.
[-exclude-path-list <text>,…]
- Exclude List of Paths (privilege: advanced)-
This specifies an array of directory names that need not be populated.
The path provided should be absolute path. If same path provided is for include and exclude path list then include-path will take the preference
The following example triggers FlexCache volume prepopulate:
cluster1::> flexcache prepopulate start -cache-volume vol_cache2_vs3_c2_vol_origin1_vs1_c1 -cache-vserver vs3_c2 -path-list /dir1 -isRecursion false (volume flexcache prepopulate start) [JobId 164]: FlexCache prepopulate job queued.
cluster1::> flexcache prepopulate start -cache-volume vol_cache2_vs3_c2_vol_origin1_vs1_c1 -cache-vserver vs3_c2 -path-list /dir1 (volume flexcache prepopulate start) [JobId 188]: FlexCache prepopulate job queued.
cluster1::> flexcache prepopulate start -cache-volume vol_cache2_vs3_c2_vol_origin1_vs1_c1 -cache-vserver vs3_c2 -path-list /dir1, dir5, dir6 (volume flexcache prepopulate start) Error: command failed: Path(s) "dir5, dir6" does not exist in origin volume "vol_origin1_vs1_c1" in Vserver "vs1_c1".
