ONTAP commands
system controller hardware-license show
Display hardware license status on the controller
The system controller hardware-license show command displays information about the controller's hardware license. The command display the following information:
  • Status
  • Is Valid?
  • Is Permanent?
  • Expiration Date
The following example displays hardware license status:
cluster1::> system controller hardware-license show
Status      Is Valid?   Is Permanent?  Expiration Date
Supported   true        true           -
cluster1::>
