system controller hardware-license show
Display hardware license status on the controller
The system controller hardware-license show
command displays information about the controller's hardware license. The command display the following information:
Status
Is Valid?
Is Permanent?
Expiration Date
The following example displays hardware license status:
cluster1::> system controller hardware-license show Status Is Valid? Is Permanent? Expiration Date ---------- --------- ------------ ---------------- Supported true true - cluster1::>
