ONTAP commands
security multi-admin-verify request delete
Delete a request
The security multi-admin-verify request delete command deletes the specified request.
-index <integer> - Request Index
This allows the user to specify the index of the request to be deleted.
The following example deletes the request with index 1:
cluster1::> security multi-admin-verify request delete -index 1
