The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security multi-admin-verify request delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a request
The security multi-admin-verify request delete
command deletes the specified request.
-index <integer>
- Request Index-
This allows the user to specify the index of the request to be deleted.
The following example deletes the request with index 1:
cluster1::> security multi-admin-verify request delete -index 1
