The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver audit enable
PDF of this doc site
Creating your file...
Your file is ready
Enable auditing
The vserver audit enable
command enables auditing for a Vserver.
-vserver <vserver name>
- Vserver-
This parameter specifies the name of the Vserver for which auditing is to be enabled. The Vserver audit configuration must already exist.
[-force <true>]
- Force Enable (privilege: advanced)-
This parameter is used to ignore errors while enabling auditing.
The following example enables auditing for Vserver vs1:
cluster1::> vserver audit enable -vserver vs1
