The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs users-and-groups privilege remove-privilege
PDF of this doc site
Creating your file...
Your file is ready
Remove privileges from a user or group
The vserver cifs users-and-groups privilege remove-privilege
command removes privileges from a local or Active Directory user or group. This command creates a new or modifies an existing privilege entry.
-vserver <vserver name>
- Vserver-
This specifies the name of the Vserver.
-user-or-group-name <CIFS name>
- User or Group Name-
This specifies the name of the local or Active Directory user or group.
-privileges <Privilege>,…
- Privileges-
This specifies the list of privileges to be removed from this user or group.
The following example removes the previously added "SeTcbPrivilege" and "SeTakeOwnershipPrivilege" privileges from the user "CIFS_SERVER\u1".
cluster1::> vserver cifs users-and-groups privilege show Vserver User or Group Name Privileges -------------- ---------------------------- ------------------- vs1 CIFS_SERVER\u1 SeTcbPrivilege SeTakeOwnershipPrivilege cluster1::> vserver cifs users-and-groups privilege remove-privilege -vserver vs1 -user-or-group-name CIFS_SERVER\u1 -privileges SeTcbPrivilege,SeTakeOwnershipPrivilege cluster1::> vserver cifs users-and-groups privilege show Vserver User or Group Name Privileges -------------- ---------------------------- ------------------- vs1 CIFS_SERVER\u1 -
+ + The following example removes "SeBackupPrivilege" from the group "BUILTIN\Administrators".
cluster1::> vserver cifs users-and-groups privilege show This table is currently empty. cluster1::> vserver cifs users-and-groups privilege remove-privilege -vserver vs1 -user-or-group-name BUILTIN\Administrators -privileges SeBackupPrivilege cluster1::> vserver cifs users-and-groups privilege show Vserver User or Group Name Privileges -------------- ---------------------------- ------------------- vs1 BUILTIN\Administrators SeRestorePrivilege SeSecurityPrivilege SeTakeOwnershipPrivilege
