vserver cifs users-and-groups privilege remove-privilege
Remove privileges from a user or group
The vserver cifs users-and-groups privilege remove-privilege command removes privileges from a local or Active Directory user or group. This command creates a new or modifies an existing privilege entry.
-vserver <vserver name> - Vserver
This specifies the name of the Vserver.
-user-or-group-name <CIFS name> - User or Group Name
This specifies the name of the local or Active Directory user or group.
-privileges <Privilege>,…​ - Privileges
This specifies the list of privileges to be removed from this user or group.
The following example removes the previously added "SeTcbPrivilege" and "SeTakeOwnershipPrivilege" privileges from the user "CIFS_SERVER\u1".
cluster1::> vserver cifs users-and-groups privilege show
Vserver        User or Group Name           Privileges
vs1            CIFS_SERVER\u1               SeTcbPrivilege
cluster1::> vserver cifs users-and-groups privilege remove-privilege -vserver vs1 -user-or-group-name CIFS_SERVER\u1 -privileges SeTcbPrivilege,SeTakeOwnershipPrivilege
vs1            CIFS_SERVER\u1               -
+ + The following example removes "SeBackupPrivilege" from the group "BUILTIN\Administrators".
This table is currently empty.
cluster1::> vserver cifs users-and-groups privilege remove-privilege -vserver vs1 -user-or-group-name BUILTIN\Administrators -privileges SeBackupPrivilege
vs1            BUILTIN\Administrators       SeRestorePrivilege
                                            SeSecurityPrivilege
