The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network options send-soa show
PDF of this doc site
Creating your file...
Your file is ready
Display Send SOA settings
This command displays whether sending the statement of authority record (SOA) in the DNS response is enabled or not.
cluster1::> network options send-soa show Enable sending SOA: true
