The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
metrocluster configuration-settings mediator remove
PDF of this doc site
Creating your file...
Your file is ready
Tear down connections between the Mediator and MetroCluster nodes
The metrocluster configuration-settings mediator remove
command removes the connection between the mediator and all the nodes in a MetroCluster configuration.
Mediator username and password are required to successfully remove the mediator.
[-dr-group-id <integer>]
- DR Group Id (privilege: advanced)-
Specifies the Disaster Recovery Group Identifier for which the mediator connections need to be removed.
The following example removes the connections between the nodes and the mediator in a MetroCluster configuration over IP setup:
clusA::> metrocluster configuration-settings mediator remove Removing the mediator and disabling Automatic Unplanned Switchover. It may take a few minutes to complete. Please enter the username for the mediator: mediatoradmin Please enter the password for the mediator: Confirm the mediator password: Disabling Automatic Unplanned Switchover for all nodes in the cluster... Removing mediator mailboxes... Performing final cleanup... Successfully removed the mediator.
