metrocluster configuration-settings mediator remove
Tear down connections between the Mediator and MetroCluster nodes
The metrocluster configuration-settings mediator remove command removes the connection between the mediator and all the nodes in a MetroCluster configuration.
Mediator username and password are required to successfully remove the mediator.
The following example removes the connections between the nodes and the mediator in a MetroCluster configuration over IP setup:
clusA::> metrocluster configuration-settings mediator remove
Removing the mediator and disabling Automatic Unplanned Switchover. It may take a few minutes to complete.
Please enter the username for the mediator: mediatoradmin
Please enter the password for the mediator:
Confirm the mediator password:
Disabling Automatic Unplanned Switchover for all nodes in the cluster...
Removing mediator mailboxes...
Performing final cleanup...
Successfully removed the mediator.
