ONTAP commands
metrocluster configuration-settings mediator remove
Tear down connections between the Mediator and MetroCluster nodes
The metrocluster configuration-settings mediator remove command removes the connection between the mediator and all the nodes in a MetroCluster configuration.
Mediator username and password are required to successfully remove the mediator.
[-dr-group-id <integer>] - DR Group Id (privilege: advanced)
Specifies the Disaster Recovery Group Identifier for which the mediator connections need to be removed.
The following example removes the connections between the nodes and the mediator in a MetroCluster configuration over IP setup:
clusA::> metrocluster configuration-settings mediator remove
      Removing the mediator and disabling Automatic Unplanned Switchover. It may take a few minutes to complete.
      Please enter the username for the mediator: mediatoradmin
      Please enter the password for the mediator:
      Confirm the mediator password:
      Disabling Automatic Unplanned Switchover for all nodes in the cluster...
      Removing mediator mailboxes...
      Performing final cleanup...
      Successfully removed the mediator.
