metrocluster configuration-settings mediator remove
Tear down connections between the Mediator and MetroCluster nodes
The metrocluster configuration-settings mediator remove
command removes the connection between the mediator and all the nodes in a MetroCluster configuration.
Mediator username and password are required to successfully remove the mediator.
[-dr-group-id <integer>]
- DR Group Id (privilege: advanced)-
Specifies the Disaster Recovery Group Identifier for which the mediator connections need to be removed.
The following example removes the connections between the nodes and the mediator in a MetroCluster configuration over IP setup:
clusA::> metrocluster configuration-settings mediator remove Removing the mediator and disabling Automatic Unplanned Switchover. It may take a few minutes to complete. Please enter the username for the mediator: mediatoradmin Please enter the password for the mediator: Confirm the mediator password: Disabling Automatic Unplanned Switchover for all nodes in the cluster... Removing mediator mailboxes... Performing final cleanup... Successfully removed the mediator.
